http://www.poolforum.com/pf2/showthread.php?t=4094
If I can get on top of my work/home projects, I'll update. No good way to add a table using the present forum so I've been pasting screen captures.
26,000 Vynil Liner L Inground
Hayward 1HP Superpump + Hayward Pro Grid 4800 DE Filter
Poolvergnuegen thepoolcleaner Pressure Side Cleaner
Loop-Loc Mesh cover
The answer depends on the FC level itself since most of the chlorine is lost due to breakdown from sunlight so it's a FRACTION of the FC that gets broken down over time, not an absolute number. Losing around half of the FC level during the day seems to be typical on the high side. Some have reported maintaining high CYA levels and seeing far less usage.
So how much of the 5 ppm FC do you lose in a day with your 60 ppm CYA level? If it's more than 2.5 ppm FC, then you might have other consumption related to organics in the pool or nascent algae growth. Your chlorine consumption overnight when the sun isn't shining will give you some idea of this extra chlorine usage.
Richard
My chlorine consumption in Central PA has been running about 70 oz (6%) per day. I have maintained a FC level of 4.2 ppm for about a week by injecting the chlorine mix directly into the return line using a peristaltic pump. The injection pump runs whenever the pool circulating pump runs which I currently have set to run 7 hours (10AM to 5PM)
My CYA is 25.
Water temp is ~70
I am not using a solar cover yet because of the birds. (that's another story)
My night time CL consumption is nearly zero so.......
Basically the system works like an erosion feeder but I don't use pucks and no CYA increase. This is an experiment which (knock on wood) seems to be working.![]()
So, 70 ounces of 6% bleach in 27,038 gallons is 1.25 ppm FC per day which with a level of 4.2 ppm FC is a loss of about 30% of the FC level per day. That's pretty good, especially with a CYA of 25 and no cover. The cooler water temp of 70F might be helping there. Keep us posted as it (hopefully) gets warmer for you in the summer. Not having any loss at night indicates that your chlorine loss is probably almost all due to breakdown from sunlight (and maybe a small amount with outgassing of hypochlorous acid).
Richard
For bleach and chlorinating liquid, you want to use the "Trade %" since that is the volume % of available chlorine. One gallon in 10,000 gallons produces an FC level equal to the Trade % (one liter in 10,000 liters does the same thing). This is because "percent" is per 100 so putting this into one in 10,000 is a net of one in 100*10,000 = 1,000,000 or one in a million which is "parts per million". 6% bleach has a trade % of 6.17 so that means that one gallon in 10,000 gallons will produce 6.17 ppm FC. So (10000/27038)*6.17 * (70/128) = 1.25 ppm FC. You can see that you scale down due to your larger pool (i.e. the same amount of chlorine results in less of a rise in FC since it's in a larger volume of water) and you scale to units of gallons using 128 ounces per gallon.
Then, 1.25 / 4.2 = 29.8%
For practical purposes, you can just use the % Weight of sodium hypochlorite, or 6%, in the calculation and not be that far off. You would get 1.21 ppm FC if you did that.
Richard
GREAT --- As usual you come through. I had the right numbers but was not taking the trade %.
What would you consider to be an acceptable burn off rate. You mentioned mine came out to ~30%
Thanks again ---
I also am in PA (Philadelphia area) and use a solar cover on cold days-no sun days. Water temp around 80-85 deg (solar and heater). I lose 0.7ppm Chlorine per day with no solar cover (off during the day and on at night) and 0.2ppm per day with a solar cover on during the day. These figures good for 2 wks now during the month of May for my 30,000 gal concrete pool. My CYA is 35ppm and I maintain Cl at the 1-2 ppm level using Chlorox 6%(I also use a Nature 2 system which allows me a lower Cl and no algae problems).
For anybody interested, this thread eventually turned into a discussion on how to put a peristaltic pump in the pool. I moved that part of this discussion to the China Shop, so if you want to participate in that discussion, please do so there. I feel that it is a bit complicated for the average person learning to control their pool chemistry.
Thanks Janet,
I agree that this forum was not the place for that discussion. Thanks for moving it for me.
