Results 1 to 10 of 15
Thread: Adding cal-hypo to pool
    Default Adding cal-hypo to pool
    I recently purchased a 25# bucket of cal-hypo from "In The Swim". I don't have anything against the BBB method, but I need to raise my CH this year.
    Anyway, the bucket says to broadcast the powder into the "deepest part of the pool". My concern is that if there are undissolved granules settling on the bottom of my vinyl lined pool, won't this bleach my liner? Can I pre-dissolve cal-hypo in water prior to adding to the pool?
    24' x 15' x 52" AG Pool
    Hayward S180T Sand Filter/1 HP Pump
    Default Re: Adding cal-hypo to pool
    You are absolutely correct that for a vinyl pool you should pre-dissolve the Cal-Hypo in a bucket of water before slowly pouring it over a return with the pump running in the deep end. Cal-Hypo does not dissolve particularly fast, especially compared with Dichlor or Lithium Hypochlorite.
    Richard
    Why do you need to raise your calcium in a vinyl pool? Do you have a heater or a salt-water chlorine generator?
    If not, there's no reason to raise your calcium. It doesn't do much in vinyl pools--unless you have too much.
    Still, there's also no reason not to use Cal-Hypo to chlorinate, as long as your calcium level is not too high.
    Honesdale PA
    With the sand filter you can also dump it in the skimmer, gets trapped in the sand filter, and is dissolved there. Just make sure you run the pump for a couple hours. In flowing water the granules dissolve pretty fast as I sometimes get a little lazy/sloppy and some granules wind up laying in the skimmer housing in flowing water. It is soon gone.
    Thank you for all your replies. Your right, I don't really need to raise CH with a vinyl liner. I know it may cost a little more (I haven't done the calculation yet, but I like the idea of just adding a few ounces to superchlorinate instead of having to lug gallons of bleach.
    I also learned quickly to wear old clothes when mixing the cal-hypo/water solution!
    Can't argue with that logic. The problem with Tri-Chlor, Di-Chlor and Cal-Hypo is that they all add something you eventually don't want any more of. Bleach doesn't.
    What I do is buy the 12.5% blue carboys and mix it half and half with water in my old gallon bleach jugs. Less hauling that way, I reuse jugs, and I get 10 gallons of 6.25% for about $16 or $17.
