hole in liner
Hi,
I have an above ground pool with a liner. I noticed that i have a hole about the size of a nickle about half way up the pool. Right now it is above the water line. I have tried the self adhesive patch, but it fell right off. I also tried the patch that you apply your own adhesive, however when i apply it, the sides curl up. any suggestions?
thanks
- You may not post replies
- You may not edit your posts
Forum Rules
