Thread: hole in liner
    Jul 2006
    long island, ny
    Default hole in liner
    Hi,
    I have an above ground pool with a liner. I noticed that i have a hole about the size of a nickle about half way up the pool. Right now it is above the water line. I have tried the self adhesive patch, but it fell right off. I also tried the patch that you apply your own adhesive, however when i apply it, the sides curl up. any suggestions?
    thanks
    Default Re: hole in liner
    Tara, try cleaning the area first, if there's dead algae or other stuff, it will interfere with the glue. You can use a wallpaper seam roller (~1" roller used to seal the seams in wallpaper) to keep pressure on the patch while the glue is setting, just keep rolling back and forth & up and down.
    There is another 'do or die' trick, but I hesitate to mention it for fear someone could ignore my warning a nd further harm their liner. I'll post it if you can't get another patch to stay after following the above advice.
    Give it another good try and if that doesn't work, I'll give the other way
    p.s - the quicker you apply the patch after putting the glue on, the less chance of the curling
    Jul 2006
    long island, ny
    thanks, ill give it a try and let you know.
    Honesdale PA
    When I was experimenting in preparation for laying a deep end patch I tried a couple patch kits and the adhesives would quickly curl the patch making it almost impossible to lay correctly. Boxer-100, available at pool stores is a slow acting adhesive that won't curl a patch. The downside is it takes time to cure once the patch is placed. Have not tried patching on a wall. A bottom patch is easy....just drop a sandbag on it for a couple days. For the side you may be able to hang a sand filled pillowcase over the side to get some force on it. Don't need much force, just a little to keep it in place while it sets. Anyhow...you may want to give it a try.
    http://www.boxeradhesives.com
  1. How to find a hole in the liner?
    By MaxxFusion in forum In-Ground Pool Construction and Repair
    Last Post: 01-11-2014, 04:13 PM
  2. Hole in liner, again!
    By TC CPT in forum In-Ground Pool Construction and Repair
    Last Post: 05-26-2008, 02:06 PM
  3. Hole in Liner
    By spcchap in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-13-2007, 01:31 PM
  4. Finding a hole in liner
    By Joe44 in forum In-Ground Pool Construction and Repair
    Last Post: 08-17-2006, 05:58 PM
