Thread: How long until I can test for CYA levels?
    Default Re: How long until I can test for CYA levels?
    My pool is 14,600 gallons and the pump has been running 24 hours for 6 days straight w/o a backwashing.
    According to this site: http://www.csgnetwork.com/poolchemcalc.html
    I can add 6# of CYA to get the level to 50ppm
    I'm just curious how long after the sock is empty do i have to wait for the reading to be accurate...
    thx
    catnip is offline Registered+ Thread Analyst catnip 0
    Blue Mountain Beach, FL
    CYA does not dissolve readily in water, so it can take a while to fully dissolve. How long depends on water temperature and water flow around the particles. But based on my own personal experience and others who have posted here, a week should be plenty.
    With you CYA at 50 ppm (when it eventually gets there) you will need to keep you FC at between 3 and 6 ppm ALL the time to keep a good level of sanitizing chlorine. Here is a post that gives the specifics:
    http://www.poolforum.com/pf2/showthread.php?t=365
    Chuck
    16,000 gallon gunite/plaster, Pool Pilot Digital SC-60, Pentair UltraFlow 1 HP pump, Pentair Tagelus TA 60 filter, Polaris 280
    Lafayette, IN
    My pool person once told me that the pool water had to reach a certain temp (I think she said 75 degrees) before it's worth while to test for CYA. Has anyone else heard this?
    Many of the chemical tests should be done with the water closer to room temperature. They are designed to be measured at those temps (70-85). You can just let the water remain covered in its container sitting at room temperature until it warms up. Then do the test.
    If the water is cold, then the CYA test will not form a precipitate as quickly in 30 seconds. If you let the water warm up first before doing the test, then it should be fine.
    Richard
