Well, only two likely causes. One is that you are adding a chemical with calcium. That's out, since you don't. The other is that the calcium is coming from the pool itself. That would be bad. A third option would be that you have a test issue. Have you tried having a pool store test your water to see what they get? I'm concerned that you may be overdoing the acid and dissolving your pool.
