ndillion2,
I don't have a problem with scaling on the Cell.( other than the normal build up.) I clean it maybe once a month or so. Other than my CH being 550 all other chemicals are perfect. The pool itself is crystal clear.
Post all your chemical readings and maybe someone can better help with your problem.
Based on all the help I am going to raise my borates to see if it will slow my PH rise.Also I may airate the pool and get the TA down to 80. Thank you all for you information .
