Thread: Chlorine level
    Default Chlorine level
    If CYA is 30 we shoot for 1-3ppm of FC. Why not higher? Keeping it a little higher would reduce the need to check it so often if you're afraid of it dropping. With an SWG you don't notice the higher chlorine levels, so is there a good reason not to keep it elevated? Just thinking out loud...
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: Chlorine level
    Since most SWG recommend a CYA in the 60-80 ppm range and many people have found that keeping their pools with SWGs in the 3-5 ppm range works well they are actually keeping their pools at a LOWER FC level then Ben's chart suggests for the CYA level (5-10 ppm FC). If you are keeping your CYA at 30-50 ppm then Ben's chart suggests keeping trhe FC at 3-5 ppm.
    Alright, but that's not really my question. Why 3-5ppm FC? Why not 10 just to be safe and ensure there is plenty in the pool?
    Ohm_Boy is offline Registered+ Thread Analyst Ohm_Boy 0
    I suppose you could keep it high to a degree. CYA tends to 'buffer' the chlorine - it not only keeps some in 'reserve', as it were, it also kinda takes the edge off the chlorine too, making it less 'harsh'. It makes it not as aggressive to fabric, vinyl, eyes and hair.
    As long as you can keep the CL levels below the point at which it tends to cause problems at a given CYA level, you should be OK.
    Sorry about the phrase-ology, but it helps me to understand things.
    mas985's Avatar
    Pleasanton, CA
    The life of a SWG cell is directly proportional to time it is on. The higher the chlorine level, the longer the cell must be on and therefore the shorter the life of the cell.
    There is enough chlorine at 3-5 ppm so why go to 10? If you start having issues (i.e. cloudy water or algae) at 3-5 ppm, that is when I would bump it up.
    Last year I ran mine at 1-2 ppm with a CYA of 60 ppm without any problems at all. So I don't think you have anything to worry about. This year I am at 2 ppm with a CYA of 40 ppm and still no problems.
    Mark
    Quote Originally Posted by Ohm_Boy View Post
    No "problem". Helps me 'understand'.
    Quote Originally Posted by mas985 View Post
    I understand that but I live in Michigan so my SWG gets used about 4-5 months and should last twice as long as most people's.
    I think you're right, and my water is finally clear and has been for a good week or so so maybe I have it figured out after all. I'll quit worrying about it.
    Thanks.
  1. Unable to keep chlorine level and CYA level has dropped from 38 to 21 in 1 day.
    By lizbyrne2000 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2013, 12:41 PM
  2. CYA level and chlorine level and pool store recomendation
    By Fishcrazy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-21-2011, 11:25 AM
  3. chlorine level ?
    By LazyLgrecian in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-09-2007, 08:57 PM
  4. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
