Thread: More Problems
    p.p.h. is offline ** No working email address ** p.p.h. 0
    Dec 2005
    Phoenix, AZ, usa.
    Default More Problems
    http://www.poolforum.com/pf2/showthread.php?t=688
    Thats problem #1
    Problem number 2 is that my salt readings are 4500. Thats what the unit is telling me. Is this an emergency that calls for immediate drain and refill?
    When Monday rolls around Im gonna call up the installers boss and let them know what happened.
    Katy, TX
    Default Re: More Problems
    I think your display is reading a bit high. From your other thread, you mentioned you have a 10K gal pool. You also mentioned that you found 7 40# bags in the trash. That's 280# of salt, and that should have brought your salt level up to 3300 or so. Of course, that's assuming that all the bags that he used ended up in the trash at your house.
    What is your unit supposed to run at? Most are 3200, so you aren't far off (technically) from that number.
    Dec 2005
    Phoenix, AZ, usa.
    I dont know if the fill water had salt in it but at the level its at, it definitely tastes salty. The unit recommends 3000-3500 with 3250 being optimum.
    Katy, TX
    Seems to me that what you'd want to do at this point is have a salt test done. The displays aren't always 100% accurate.
    Michael
    Stafford, Virginia, US.
    Quote Originally Posted by mwsmith2
    Michael
    I agree 100%... Most of the SWG can actually handle salt to very high levels... For example, I think the Pool Pilot can handle up to 35,000PPM but I am not sure how that effects the cell itself. I would "assume" it shortens the life... My water somehow got to 4100ppm when I added the required salt but I think my water was not at 0ppm when I started... I just ran a pool cover pump I had and as I pumped water out I had a hose adding water in on the other end... I am now down to 3700 after running it a couple hours yesterday... The pump has an 1800GPH rating... Probably more like 1500 actual... My pool is 26,400gals so I will have to do it again today... I had a slight salt taste but not too bad...
    Scott
    Ft Lauderdale, Fl
    Well actually, the salt recommendation are very much different and not many domestic units recommend higher than 3500 ppm. Most Australian units recommend between 4000 - 6000 ppm. The reason is mostly in the power supply design than direct effects on the cell.
    PPH, if you still have problems with your system, you can e-mail me directly, I can most likely help you with this (I hired the most knowledgable person on AutoClear in the industry!).
    [email protected]
    Sean Assam
