Thread: New Pool/new House Well Water
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    Default Re: New Pool/new House Well Water
    I just completed a new 26K gallon pool install and filled it with iron rich well water. However I took the following steps to remove/prevent metal contamination.
    1. I put a whole house 2 micron filter ahead of the water softener.
    2. Used the water softener to fill the pool. It took many pounds of salt and regeneration cycles to complete. I used softener salt that contained an Iron Out additive (Citric Acid)
    3. During the 5 days that the pool was filling I added metal out and Polyquat 60%
    4. I used a Pentair 26" sand filter loaded with Zeolite media and let the pump circulate several days before switching on the SWG, I did not shock the pool.
    5. I switched on the SWG and let it bring the FC levels up to 3.5PPM with 40PPM stabilizer
    6. Now that I have the salt levels where I want them all fill water comes straight from the well, but I run it though the same 2 micron whole house filter cartridge before it gets to the pool.
    The water has been crystal clear since startup with no staining.
    As a side note...we have so much iron in the water that I have to change out the filter cartridge monthly. When it is removed it is orange/red in color and about 3 times it's original weight. Well water can be used if you take precautions before filling.
    33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
    Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
    Aqualuminator with Fountain -- Solar Pool Lights
    Pool Pictures at the link below
    http://community.webshots.com/album/548241672nKeuyR
