Results 1 to 8 of 8
Thread: Backwash hose-Walmart vs Pool Store
    Kansas
    Default Backwash hose-Walmart vs Pool Store
    Hi All,
    Quick question:
    Is there any difference between the backwash hoses sold at Walmart and the ones sold at the pool stores?
    Thanks,
    ~Hoffmans
    Default Re: Backwash hose-Walmart vs Pool Store
    If you're talking about the flat blue hoses, I prefer my walmart one over my pool store one, a littel bigger and slightly more flexible - less likely to split in colder weather.
    I use them to run my rainbarrel overflow to the pool over my lawn in the spring to fill the pool - about 100 feet - works like a water level, top of pool is about 2 feet lower than top of rainbarrel.
    Generally you can find better products for less money at any place other than a pool store. When they put the word pool on it, it just adds to the mark-up.
    Quote Originally Posted by cleancloths View Post
    Not necessisarily! Skimmer socks are 3 for $6 and change at walmart and 5 for $5 and change at the pool store in my area! It pays to comparison shop!
    Well there are exceptions to everything, but generally pool stores are high. Take a look at the price of a ball valve there versus at one of the big box hardware stores.
    Then again, therre is a REAL difference in quality between a ball valve from a big box and a Jandy or Hayward ball valve. If you don't believe me just check them out! Just try turning them both and you will see what I am talking about.
