Thanks,
I just read the "test" you can perform to prove it works. The funny thing is they tell you to use water that is 110 degrees. Well sure, the evap rate is going to be high at that temp, AND your only looking at a 5-6 degree difference. Bring that down to 70-80 degree range and your not looking at much.
Wayne
