Re: Replacement pump
Well sure enough. Hidden between the 3/4 and 1 hp Northstar models poolplaza lists a 1/2 hp fullrated one for $414.07. They also list an up rated 1hp dual speed Super Pump for a whopping $529.65.
Any reason to go with the 2 speed 1 hp Super Pump over a 1/2 hp Northstar? Seems like the Northstar would have the same current draw as the 1 hp on low speed, yet put out the flow of the 1hp on high speed.
