Thread: Mars HP Freshly installed - First Impressions/Questions
    Default Re: Mars HP Freshly installed - First Impressions/Questions
    It does not climb the 90 degree walls, just my slopes in the deep end hopper. Even then it only goes about a foot or so up them. It does go up the ramp part to the shallow end then veers off to the side and pretty much runs the shallow end edge around again and back to the deep section.
    62,800 Litre IG Vinyl
    1HP Super Pump
    Clearwater LM2-24S SWG
    250K NG Heater
    Mars HP Pool Sweep
    I would leave the tail on. I have found that if the tail is slightly to one side intead of directly underneath the unit will climb my stairs better but it tends to make it go into a circular path a bit. Hose length and float position are important for proper climbing and good coverage. Leaving the hose straight in the sun for a few hours will take care of the coiling. It will clean better then. If the backup valve is pulling it out of the ladder then it's working properly! Mine is running at about 43-44 rpm. That's the highest it will go on my system. Mine climbs the walls pretty well and gets maybe a foot below the suface of the water sometimes. Usually it will go up a bit more than halfway in the deep end. The cleaner does spend more time in the deep end than the shallow end but my returns are in the shallow end and that might have something to do with it.
    Thanks for the tips guys. It is appreciated. I have put the tail back on, and today it seems to be cleaning better then yesterday. I am going to let it clean the pool 3 hrs a day for the week then let the hoses straighten out in the sun if I am still noticing the coiling. Will re-measure after that as well.
    One more question though, can I run it under my pool solar cover or is it not a good idea?
    Thanks.
    1HP Super Pump
    250K NG Heater
    Mars HP Pool Sweep
    Mantua, NJ
    I run mine under the solar cover. You may have your hose tangle until the residual coils are gone. Remember to lay your new hose out in the sun to help remove the coils.
    Joe
    Thanks Joenj, wasn't sure if I needed to worry about the cover.
    The cleaner is definately improving in its climbing ability. I did angle the jet wand things that hangs off the back to the side a little from straight down. It now comes about a foot from the water line in the deep end. Still need to sort out the shallow end problems. I will play some more over the weekend after I check the float positions and let the hose straighten out on the deck for 4 hours in the sun.
    It does do a good job though on the areas it hits. I have been brushing the areas it does not really go over towards the deep end. Pool looks really clean when its finished its 3 hour tour.
    Once again thanks to you Waterbear for the assistance as well.
    1HP Super Pump
    250K NG Heater
    Mars HP Pool Sweep
  1. New Pool Installed Thursday - Some newbie questions
    By Jacob99 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-29-2012, 02:04 PM
  2. Zodiac Mars HP o-ring
    By JonnyG in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-29-2009, 03:50 AM
  3. Mars HP pressure side cleaner and NO booster pump
    By waterbear in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-21-2007, 08:50 PM
  4. Cloudy water in freshly re-filled pool
    By lynnybug55 in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-12-2007, 05:22 PM
  5. Just installed SWG, questions on salt level
    By noworries in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-16-2006, 03:12 AM
