Thread: Mars HP Freshly installed - First Impressions/Questions
    Default Re: Mars HP Freshly installed - First Impressions/Questions
    Thanks for the tips guys. It is appreciated. I have put the tail back on, and today it seems to be cleaning better then yesterday. I am going to let it clean the pool 3 hrs a day for the week then let the hoses straighten out in the sun if I am still noticing the coiling. Will re-measure after that as well.
    One more question though, can I run it under my pool solar cover or is it not a good idea?
    Thanks.
    62,800 Litre IG Vinyl
    1HP Super Pump
    Clearwater LM2-24S SWG
    250K NG Heater
    Mars HP Pool Sweep
    Mantua, NJ
    I run mine under the solar cover. You may have your hose tangle until the residual coils are gone. Remember to lay your new hose out in the sun to help remove the coils.
    Joe
    Thanks Joenj, wasn't sure if I needed to worry about the cover.
    The cleaner is definately improving in its climbing ability. I did angle the jet wand things that hangs off the back to the side a little from straight down. It now comes about a foot from the water line in the deep end. Still need to sort out the shallow end problems. I will play some more over the weekend after I check the float positions and let the hose straighten out on the deck for 4 hours in the sun.
    It does do a good job though on the areas it hits. I have been brushing the areas it does not really go over towards the deep end. Pool looks really clean when its finished its 3 hour tour.
    Once again thanks to you Waterbear for the assistance as well.
    1HP Super Pump
    250K NG Heater
    Mars HP Pool Sweep
