Re: Mars HP Freshly installed - First Impressions/Questions
Thanks Joenj, wasn't sure if I needed to worry about the cover.
The cleaner is definately improving in its climbing ability. I did angle the jet wand things that hangs off the back to the side a little from straight down. It now comes about a foot from the water line in the deep end. Still need to sort out the shallow end problems. I will play some more over the weekend after I check the float positions and let the hose straighten out on the deck for 4 hours in the sun.
It does do a good job though on the areas it hits. I have been brushing the areas it does not really go over towards the deep end. Pool looks really clean when its finished its 3 hour tour.
Once again thanks to you Waterbear for the assistance as well.
62,800 Litre IG Vinyl
1HP Super Pump
Clearwater LM2-24S SWG
250K NG Heater
Mars HP Pool Sweep
