Welcome to the forum. We're going to need some more numbers to be able to help. We need to know your cya reading. Instead of using HTH Sock-It, just use plain, unscented bleach to chlorinate with. It will not cloud your water. Also, we don't trust test strips. Get a drops based kit and repost with current readings. Then, somebody here should be able to help you.
