Thread: Help! from pond to clear to cloudy OH MY!!
    mbar's Avatar
    Ashland, PA
    Default Re: Help! from pond to clear to cloudy OH MY!!
    Your alkalintiy is low, and your ph is on the low side. You will need to add about 40 lbs of baking soda, or you can use alkalinity up according to the directions on the bucket. Your alkalinity should be at 80 to 120. Ph at 7.2 is good since you are going to have to shock the pool - you will want to add about 6 gallons of bleach to your water to get it up to shock, which if you have no cya will be about 12ppms. you will have to invest in a good test kit so you will be able to test that high. You have to know how much cya you have so that you can see how much bleach you have to add to really do the job according to the "best guess chart" sticky at the top of the chlorine forum. If you have higher cya, you will need to get your level higher to get to shock. You really do have to know the numbers on your chemicals, this way you will be able to tell us, and we can help you understand how to keep your pool clear.
    Northeast PA
    Jul 2006
    Thank you guys! I've been looking around all weekend for a kit that can test CYA....but no luck locally. I am ordering a kit online because the ones I have are not suitable for this task(I understand what you all mean about the numbers!) and I may try to get my water tested at the local pool store(at the risk of them trying to sell me every chemical under the sun). I bought some CYA in case I need it. thanks again for spoon feeding me....I'll post when I can get all the numbers...Kim
  1. Water is cloudy. Want to clear up before closing
    By Jacob99 in forum Dealing with Algae & Slime
    Last Post: 09-29-2012, 07:38 PM
  2. Clear up cloudy water
    By bross1990 in forum Dealing with Algae & Slime
    Last Post: 07-26-2012, 02:59 PM
  3. Cloudy water won't clear up
    By Batman77 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-25-2011, 08:21 AM
  4. Clear Above, Cloudy Under
    By rljagr in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-14-2006, 08:29 AM
  5. Can't clear cloudy water
    By ScrltOTara in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-02-2006, 08:44 PM
