thanks for responding Sean. I have "two speed pump" selected in the installer menu.
Program 1:
set high pump hours 10
set high pump minutes 15
(so it would start at 10:15)
set low pump hours 1
set low pump minutes 15
(so it low pump would come on at 1:15)
after that there is no other options its goes back to the menu. Same program options for program 2, which is not programmed. Do I need to program that also with the same hours?
Does that mean my pump will be running 24hrs?
If I switched to "external timer" can I use my original filter timer and the Autopilot would shut itself off because of no flow?
I checked the "pump" button, when the pump is on low speed it shows high speed and I switched the pump to high speed and the "pump" button still reads high speed. Does that mean the installer didnt wire it for 2 speed? I called him yesterday to ask how he wired it and he didnt return my call.
I'm usually understanding of instruction manuals but this Autopilot manual isnt very specific.
thanks
Dawn
