Results 1 to 10 of 10
Thread: Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    Default Re: Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    In answer to the question regarding changing a 54 inch pool to a 48 inch or lower pool, I've seen pools with floating skimmers, meaning it does not matter where your water level sits, it will always skim - as for your return - as long as it's still emptying into the pool it should be fine...
    http://www.nextag.com/Vogue-FLOATING...31/prices-html
    http://usaink.com/dragonfly/
    Hoffmans and Pool newby, excellent advice. I have four daughters that were raised in above ground pools. We never went the floatation things, not sure they were around back then. The babies would spend a little time in tube of some sort but most of the time the kids were in my arms until they could swim away on there own. They all took after me, born half fish. Water depth has never been an issue. With a couple of air mattresses in the pool as rest stations you would be amazed at how much fun kids can have even if they can’t stand up to breath. And yes, they grow so fast.
    If depth is still a concern I would go with Matt’s suggestion. At one time over the wall skimmers went into most of the pools we built. I know, this was back before floatation devices, but they are still a very viable option. You can run your skimmer and return lines over the wall if you want to. Some flat sheet metal taped over the skimmer and return openings, from the inside, will take care of the openings until you are ready for them in a few years.
    For many, many years Doughboy pools came with these plates included in every wall in a matching color. Just tape them into place and use an over the wall skimmer. All the rest of the brands had skimmer and return openings that were like half punched and if you wanted to use them it was hammer and chisel time to get them out. If you did not wish to use them you simply taped over them.
    As for the high sand inside the pool, you would not be happy with the results. Remmember also that you will loose about 5-6 inches in depth from the sand at the bottom and the simmer level on the top. A 54" wall does not mean 54" of water.
    Now that I have aged myself back to the stone age, get the taller pool and enjoy.
    Dennis
    I agree. Our boys have always been in the regular depth with the adults since they were little babies. Baby floats and life jackets were our answer then, I think those floatie costumes are wonderful alternatives that look "cooler" for kids that care about that sort of thing, for those that don't floatation devices and good supervision (that always anyways)
    zephans is offline Registered+ Thread Analyst zephans 0
    Bothell, WA
    Talking Re: Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    Thanks for all the advice. This is awesome!
    Plan A: Go for it! I didn't know pool height didn't include loss from skimmer and sand bottom. Also pool toys will provide excellent rest stations... they will totally love it. My 6 year old does fine with breaks and place to shoot for nearby (under supervision of course).
    Plan B is floatation wear.
    Plan C is lower water and get a floating skimmer.
    Lots of options. I'm ready to order tomorrow! I just hope the sale is still on and I get someone knowledgeable to talk with on the phone before I spend ~$2,500+.
    Last edited by zephans; 05-30-2007 at 01:43 AM. Reason: Forgot to add "and get a floating skimmer" for plan C.
    Thanks! -ZephanS
    AG BF 13.5'x23.5'x54" (wups) Diamond Star (Wil-bar) purchased 5/30/2007 from sunenterprises.com. 2hp pump + 150lb sand filter (both WaterWay combo) using 75lbs zeobrite + SWG.
    Dug and built ourselves in ~30hrs by ~7/4 thanks to PF (esp. hrdennis,nwmnmom,matt4x4,Waste,CarlD, &others). ~$5,500 total cost.
    Bothell, WA
    UPDATE: I purchased the 12'x24'x54" Diamond Start pool (made by Wil-Bar) from www.sunenterprises.com. I'm confident full depth won't be a problem, but if I encounter any issues I'll update this thread. Thanks again.
    Thanks! -ZephanS
