Thread: Low PH and Alkalinity
    Jul 2006
    NC
    Default Low PH and Alkalinity
    I just put in a new liner and new water. The stabilizer and chlorine looks good, but the alkalinity was at 60 and PH at 6.8 (at least it was that orange color at the very bottom.) I bought Borax but am unsure how much to put in and do I just sprinkle it in or what? Thanks!
    Pam
    mbar's Avatar
    Ashland, PA
    Default Re: Low PH and Alkalinity
    You can use washing soda, as explained in this post by CarlD:
    Baking Soda does not raise pH significantly but it does raise Total Alkalinity (TA).
    All Chem_Geek was suggesting was that since you need to raise both pH and TA, you can use Arm&Hammer Washing Soda (in the Yellow box) rather than using both Baking Soda and Borax.
    Why would you do this? Generally, pound for pound, at the supermarket Washing Soda is a little cheaper than Borax. But more importantly you only need to add one chem to get both effects.
    99 times out a 100, I'll use Borax to raise pH, especially since I'm generally facing higher TA levels (140 or so--which is fine in vinyl pool with no heater). Borax won't increase TA levels, sort of. Washing Soda will. (as pH rises and falls, TA goes up and down with it. W/S raises the TA more than the pH rise does alone.)
    So the other day my pH was 6.9 (VERY unusual for me) and my TA was 50. IDEAL conditions for using Washing Soda rather than Borax and Baking soda.
    You can pour the washing soda right in the skimmer, slowly so that it doesn't go all over the place - how much depends on how much water your pool holds
    Northeast PA
    Washing Soda is the same chemical sold expensively as "pH Up" and other amazing names and packages that justify a price 3 or 4 times that of Washing Soda.
    Both are Sodium Carbonate (NOT the same as Sodium BI-Carbonate--baking soda).
    Jul 2006
    NC
    It's a 13,500 gallon pool (24' x 48"). Where might I find how much to add?
    mbar's Avatar
    Ashland, PA
    Try adding 2 cups, wait 2 hours, test again and see how much it went up - then take it from there.
    Northeast PA
    Jul 2006
    NC
    Quote Originally Posted by mbar View Post
    Thank you!
  1. Alkalinity stuck at 0...after 50 lbs. Alkalinity Increaser
    By heyaim in forum Dealing with Alkalinity and Calcium
    Last Post: 07-22-2012, 07:51 PM
  2. Ph or Alkalinity...which should i fix first
    By JKashJ in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-11-2008, 05:18 PM
  3. Alkalinity Low??
    By Brunomax in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2007, 03:23 PM
  4. Total Alkalinity and Adjusted Total Alkalinity
    By cheshamjim in forum Dealing with Alkalinity and Calcium
    Last Post: 06-18-2006, 09:36 PM
  5. Alkalinity FAQ
    By VickieC24 in forum Dealing with Alkalinity and Calcium
    Last Post: 04-04-2006, 11:03 PM
