Thread: Starting the conversion tonight...
    Default Re: Starting the conversion tonight...
    i also converted this may abv 17.000 sand filter just keep your level up to eat all the baq and it will turn to bath water when its ready u have to test every couple of hours and and more chorine, also i filled my pool up and vac to waste a couple of times it took me 4-days and i can see 28ft across my pool under water,
    Front Royal, VA
    Today is day 7 and I think I'm there.
    I did lose quite a bit of chlorine during each day, but always kept it high overnight.
    My cartridges are almost like new with all the bleach I've been subjecting them to and lack of biguanide.
    I can see the bottom in the deep end and now see all the silt that I need to get up.
    Now the next question for the chlorine section, how do you know what level of CYA is best?
    Front Royal, VA
    I also hijacked my own thread...
  1. Tonight we hit 80 Degrees!
    By CarlD in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-08-2008, 09:06 PM
  2. Starting the conversion... and have questions.
    By fxdwg97 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-29-2008, 09:47 PM
  3. starting conversion ???
    By larry b in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-15-2007, 12:52 PM
  4. Taking the Plunge - Baquabeast conversion starting
    By lizzie64 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-18-2006, 01:03 AM
  5. Bought a 27" ag round tonight
    By pkzmf in forum Above-Ground Pool Construction & Repair
    Last Post: 05-06-2006, 01:04 PM
