Thread: opening pool, cloudy water
    mbar's Avatar
    Ashland, PA
    Default Re: opeing pool, cloudy water
    Do you have a bottom drain in your pool? If you have the drain on the bottom open when you are trying to vacuum you will not have good suction. You have to close off the bottom drain . There should be a lever in the skimmer, under the basket. If you don't have a bottom drain, I am not sure of what else to check - hopefully someone else will chime in
    Northeast PA
    ohio
    Quote Originally Posted by mbar View Post
    There is no bottom drain, only the skimmer.
    Smile Re: opening pool, cloudy water
    How's the flow (pressure gauge) when not vac-ing? Sounds to me like a clogged filter, since it rips on waste - which by-passes the filter.
