Thread: PH over 15 - what reduced ph?
    Washington.
    Default PH over 15 - what reduced ph?
    2 questions for a 25000 gal, in ground, vinyl lined pool:
    1) Ph is above 15, how do I reduce?
    Why is my ph above 15 you ask? We had to replace our pool liner and are re filling with a friend's professional water truck - the first load was well water, the second was clean lake water (clean as in little sediment). Since his Dad is doing us a great favor, we okayed him filling in 10 min at the lake rather than 1 1/2 at the well. What we're saving on the water will be huge compared to what I may have to put in time and bleach.
    Here's what I have for our current 8,000 in the pool (will be 24300):
    FC 0
    CC 0
    TC 0
    ALK 12
    cal 14
    ph 15+
    I got the 15 by diluting the sample water with 1/2 distilled water so I could get a more accurate read after the first one was darker than 8.
    I'd like to get a start on making progress and keeping what is in there at bay while it takes a few days to get the rest of the water. The truck needs a minor pump repair to get going again.
    2) I am sorry Ben is MIA - hope he's OK. When I'm looking for replacement tests, is there any reason I need to worry about calcium with a vinyl pool? Or should I ignore this test.
    Thanks!
    Default Re: PH over 15 - what reduced ph?
    You are doing the test wrong.
    Considering that the upper limit of the pH scale is 14 and that is pure lye or Draino and highly corrosive, you are clearly doing something wrong if you get a reading of 15+. If your water had a pH of 14, when you stuck your arm in it to measure, it would burn your skin right off.
    I'm deadly serious--we are talking about pure Draino strength here.
    If you checked the pH of the distilled water you would probably find it to have a pH of 7. Therefore, diluting it would not double the reading. Your diluter is already at 7.
    pH goes from 1 (strongest acids) to 7 (neutral) to 14 (strongest bases or alkalines).
    Dilution works for measuring chlorine and some other tests, but not pH.
    I'm GUESSING that what you are doing could be like this: You get a reading past 8, off the scale. You dilute with distilled (let's assume its pH is 7 but you should measure it). Now let's assume your diluted reading is 7.6. You adjusted by doubling your reading (the spurious 15+ reading). I would adjust by doubling the part between 7--neutral and 7.6 (.6 becomes 1.2) and adding THAT to 7. That would give you a pH of 8.2 which is consistent with your first reading and won't burn your skin off.
    I'm not saying my adjustment is correct or valid--Chem_Geek or someone else with equivalent chemistry skills could do that. But I'd bet my estimate is far closer than what you did.
    In any case you need to add Muriatic Acid or Dry Acid to bring your pH down to the suggested range.
    adding more or less indicator (or diliuting) will not change the accuracy of the reading, only the intensity of the color obtained. Phenol red is the indicator used for pH in pool tests. It has distinct colors at different pH:
    yellow 6.8 and below
    yellow orange 7.0
    light orange 7.2
    orange 7.4
    red 7.6
    red violet (sort of pinkish) 7.8
    violet 8.0
    purple 8.2 and above.
    If you learn these colors your con't even need the color comparator to test pH! The color for a specific pH is always going to be the same no matter who manufactures the test, only the intensity of the color might differ.
    Depending on who made your color comparator and indicator solution the colors obatained might be very intense (such as seen in the better kits from LaMotte and Taylor) or very pale pastels that are often seen in the cheap kits with more dilute indicators. Also, the number of drops added will affect how deep or pastel the colors are. Some kits tell you to add only 1 or 2 drops, others have you add 5. You are looking at the color, not how deep or pastel it is! 7.4 will be orange! It might be a deep orange or a very pale orange but it will be orange. Ditto for the other colors and pH.
    Hope this explains it!
    Washington.
    Thanks all! Yes, I was doing the test like I would for high chlorine, assuming same type of results. That's why I stop here first!!! Can't believe I forgot about the extreme range of Ph - good thing I homeschool my kids and we just covered that a few months ago:-) Failed that retention test!
    My kit is Ben's kit from last season. I'm going to order something online as soon as I figure out what, but I live over an hour from the nearest shopping and nowhere near a professional pool store. So I just used what I had.
    Muriatic acid - duh! I should have remembered that when I was pulling my really high alk down a bit early last year.
    Carl was more on the right track in how diluting with "neutral" water affects pH. If there were no pH buffers in the water, then diluting by adding an equal amount of water at pH 7 would roughly cut in half whatever was in excess in the water you were measuring -- in this case an excess of hydroxyl ions since the pH was above 8. pH is a logarithmic scale of the concentration of hydrogen ion and that concentration is in inverse proportion to hydroxyl ion. So in this case with a pH of, say, 8:
    pH = 8 = -log10([H+]) = -log10(10^(-14)/[OH-]) = 14 + log10([OH-])
    so [OH-] = 10^(-6) so cutting this in half would be 5x10^(-7) which would result in a pH of
    14 + log10(5x10^(-7)) = 7.70
    In general, diluting in half with water that is a pH of 7 will result in moving the pH towards 7 by about 0.3 units (-log10(0.5) = 0.3).
    As for what happens when there is a pH buffer, the dilution cuts all the chemical species in half (assuming the diluting water has nothing in it) so the carbonate buffer resists the change in pH so the pH change might be even less.
    The bottom line is that you can't use dilution for the pH test.
    Richard
    I figured Richard could give a better and more detailed analysis.
    My ability to follow log-based mathematics is sadly, so ancient as to be gone... But the basic concept of dilution without a pH buffer versus with a pH buffer is perfectly logical.
    WB's alternate path is equally useful.
