Thread: Muratic Acid to swim time?
    Columbia, SC
    Smile Muratic Acid to swim time?
    How long should you wait to swim after adding Muratic Acid? Thanks, Joyce
    18,000 IG Gunite/Plaster, Hayward Sand Filter
    Default Re: Muratic Acid to swim time?
    Unless you have a huge pool with poor circulation, 10 minutes should be plenty of time for the acid to dissipate as long as the pump is running. This is especially true if you poured the acid slowly over a return in the deep end. And even this is being conservative. The pH buffer in the pool makes it safe to swim rather quickly.
    You can always test the pH in the area where you added the acid. That would give you assurance.
    Richard
    Columbia, SC
    Smile Re: Muratic Acid to swim time?
    Thanks Richard. You folks are great.
  1. Hello all and muratic acid question
    By BryanB in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-12-2011, 08:09 PM
  2. Where to buy muratic acid?
    By s0undone in forum Dealing with Alkalinity and Calcium
    Last Post: 06-11-2006, 12:41 PM
  3. Muratic Acid : 20 Baume'
    By mrmrk49 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-28-2006, 10:45 AM
  4. Dry acid versus muratic acid - and how to add?
    By west1745 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-03-2006, 01:19 AM
