Thread: Jandy pump problem
    Default Jandy pump problem
    My 5 year old jandy 2.0 hp pump(motor) is making some grinding noises . It is not a steady noise but it happens more than 50% of the time. Is it something I can check( I am not a gearhead)? If I need to replace the motor any suggestions? Can I just put a new motor on the back?
    cheers,
    Ed
    Ocoee, Florida
    Default Re: Jnady pump problem
    My neighbor had this same issue but much worse. His pump was making this ear deafening grinding noise 100% of the time, it was so loud that we could hear it inside the home and outside it gave you a headache. We finally approach them and made mention of it, he was at work when the pump was running so was unable to hear it. Anyway his solution was he just replaced the motor unit and bolted it back in. You should be able to get one thru a pool parts company local or online.
    15,000 gallon IG free form 16x32 w/attached IG 6x7 spa. Aquapure SWG, Jandy Aqualink 4 w/ PDA, Paramount infloor cleaning system, Starite 400K propane heater, Starite system 3 filter, Starite 2hp pump, polaris D'Light LED pool and spa light and paver decking. Completed in 11 weeks 7/4/06.
  1. Jandy pump problem, plus other system questions...
    By jplum13 in forum In-Ground Pool Construction and Repair
    Last Post: 06-13-2012, 06:34 PM
  2. Help with Jandy RS8 PCB Problem?
    By jdidonato in forum Pool Equipment & Operations
    Last Post: 01-06-2008, 10:39 PM
  3. Jandy SWG problem?
    By jayamberly in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-16-2006, 01:11 PM
