Results 11 to 14 of 14
Thread: How are you disposing your DE?
    Lehigh Valley, PA
    Default Re: How are you disposing your DE?
    Mine is a sand filter, can't hep with the DE disposal.
    I backwash onto my lawn, have done for 7 years, no problems. My FC generally is between 3 - 5 ppm and has not hurt the grass.
    Jun 2011
    In the Sticks near Houston, TX
    My observation with the lawn is that the pool water with ~3000 ppm salt only makes the grass greener. I normally only backwash every 2 weeks or so, or maybe longer. I have had troubles the past few years so I have backwashed more often. Sometimes I only bw once a month.
    ~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
    Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
    Scottsdale, Arizona
    Find the sewer clean out in front of your house and back wash into that . If you're not on septic that is.
    My backwash goes into my back yard, usually with5-10 ppm of chlorine, and it doesn't hurt the grass at all. As far as DE goes, some folks actually spread it onto their lawns to help control insects.
