Thread: CH Test Question
    Maryland
    Default CH Test Question
    When using the Taylor 2006 test kit for CH I get a wierd reading/response. When you add the drops that are suppose to turn it red I get a very light pink and then the pink starts to form into tiny droplets suspended in a clear solution.
    I then start to add the the drops to turn it blue and I get to a point where it turns more of a light purple color. To the best of my ability I get a reading of about 250 ppm. I tried it on my softened house water and it worked just as the instructions described.
    I have an IG vinyl/SWG pool, temp is ~85 F, FC=5.0, CC=0, pH= 7.5, and TA=140. My CYA should be about 50 ppm but I added it last Saturday so I've been waiting to measure it so it has a chance to completely dissolve.
    Anybody know why my CH test acts so strange? Thanks!
    Default Re: CH Test Question
    Try adding 4 of the titrant drops (the ones you count) first before adding the calcium buffer and indicator. Then add those 4 to your count of drops you add after the indicator. See this link for more information about this. Metal ions can interfere with the test though usually it just results in what is known as a "fading endpoint" where the color change does not stay.
    Richard
    Maryland
    Thanks for the suggestion, I will try this to see if it works. It also got me thinking when I went to the link you provided. When my pool was being filled the pool builders assistant accidently put double the amount of algaecide into the water.
    Is it possible that this is interferring with my CH testing?
    I don't think the algaecide will interfere with the CH test.
  1. CYA test question
    By oasisdave in forum DPD-FAS based testing
    Last Post: 07-14-2006, 08:10 AM
  2. First test and a Question
    By vchords in forum DPD-FAS based testing
    Last Post: 06-20-2006, 03:55 PM
  3. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
  4. CC test question
    By GolfTop in forum DPD-FAS based testing
    Last Post: 06-06-2006, 12:36 PM
  5. 233 kit - CYA test question
    By vanhout in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-17-2006, 10:21 AM
