Hey Fog!, How are you doing (other than the algae)?
With your EC 65, there is a chance that the 'slime water' willend up on the uncoated fingers and 'gunk' them up. A method to possibly minimise this is to keep the plugs in the returns, the pressure may be enough to keep the water from filling the tank. You probably know your normal filter pressure, so check to see that it's not too much higher after you coat the fingers - if it is, you'll have to break the filter apart and hose the fingers clean![]()
As for the volume, it can be figured out by breaking the pool into simple solid chunks usually, but the differing radii (and the reversed radius) make that a little tough - perhaps someone else has a formula. What I would do is measure the perimeter and multiply that # by the average depth of the pool and multiply that # by 7.5 to get a reasonably good ESTIMATE - then add chems as if it were 1/2 that size and see how much of a change you get - add more chems as needed to get your #s where you want them -- eventually (if you keep a log of results and additions) you'll get a good idea of how much of whatever chem is needed to raise the parameter X ppm.
If anyone has a better idea, I'd like to hear it as much as Fog would.
Good to see you back! - have a great summer and enjoy the pool!!![]()
