In light of another post by waste that he's pretty busy this time of year, and doesn't get on the forum as often, I'll stick with you here. But he's the expert so I welcome his input. I'm an expert on my own pump and filter in my own backyard, and that's about it. That said...
You need what one of the Mods here calls a POP test. That's Pool Owner's Patience. Assuming your chems are pretty much in line, at this point in the process the filter is still removing particulate from the water which makes it less than clear. That's why the pump needs to run 24/7. And because of the effectiveness of DE, the matrix it forms on the grids needs to be broken down and rebuilt frequently, AKA bumping. You can help to alleviate some of this congestion by putting a skimmer sock on the skimmer basket, but that does nothing for water entering through the maindrain. It will grab the surface stuff though so it may be some help.
I'm also wondering if maybe you had too much DE since you claim bumping doesn't lower the pressure less than 20psi (but after acid washing it did start out at 10).
In any case, Keep the pump running and try to remember to bump when the pressure raises 10psi or so. It might be once an hour for the first two days or so, but don't sweat it about letting the pump run at this raised pressure for a couple hours unattended (like when you're asleep!). Just make sure it's adequately ventilated, and bump it the next chance you can. You need to keep it running as much as possible the first couple days. Then you can back off to 8 hours a day, or so.
And keep the skimmer and pump baskets clean as well.
. [while I'm at it, DE filters use a coating of DE (duh!) to pre-coat the grids or fingers with a material (DE) that won't pass through the 'cloth' but will collect all but the smallest of particles. The collected particals stay on the outer surface of the DE coating and never touch the collection membrane, until you bump - bumping 'shakes' the DE coating off of the cloth and let's it drop to the bottom of the filter tank. When water starts passing through the filter again, this DE with 'scum' on it mixes with the clean stuff that was between the dirty DE and the clean DE that was on the membrane, which opens new passages for the dirty water to flow through, but not as many as a freshly cleaned and recharged coating would be. **bumping does not remove any of the dirt from the filter - unlike backwashing does - it only rearranges the clean and dirty DE to open the flow until the new channels fill up with dirt/ algae)]
