Results 1 to 9 of 9
Thread: how long & when do you run your filters?
    Jul 2006
    Wink Re: how long & when do you run your filters?
    Also, I just got a solar cover...are there any considerations with running the pump with it on? ie longer or shorter time? seems like the PB was right with the 10-12 hrs at night....Thanks for all the input ....you guys never steer me wrong thanks kim
    Scottsdale, Arizona
    Default Re: how long & when do you run your filters?
    Being in Arizona, heat loss is not an issue.
    North Florida
    myLABSpool...Wow! 3 cents/kwh??? Could your electric provider come to TX???
    But, to your point about heat loss at night...in the summer, I actually WANT to drop the temp in my pool so I log a lot of pump time in the middle of the night (unfortunately, no price break for nighttime hours here). Last year (first with the pool), we ran it 12 hours/day during the peak of summer, 11A-1P and 4P-8P and 12A-6A. My pool temp would drop from about 90-91 degrees down to 83-84 degrees by morning.
    Right now, it's running for 8 hours, 11A-1P, 4P-8P, and 3A-5A.
    Sandy
