Results 1 to 10 of 14
Thread: Pump timer
    Default Re: Pump timer
    i wouldn't worry about incirculated hot water..it has hot water running through it all the time when running, eh? i don't believe that's the issue. it's the issue of whether your heater has a cool down fan system or not. i have a jandy 2. it says nothing that i've found to indicate there is such a system in it..what it has is 2 schedule 80 pvc pipes with the intent to bleed off hot gases over their length so it's not so hot when it hits the schedule 40 pipe about 8 inches past the schedule 80 tubes. sounds great in principal but given i've been there with melted pipes when in my old system, i forgot to turn the heater off 15 minutes before the pump and came out the next morning to find water shooting all over and my pipes bent like spaghetti. i can laugh about it now, but if it had got to the pipe that goes into the ground..that could have been some major trouble. so, i have a 12 minute pre-shut off switch built into my system to shut the heater off that amount of time before the pump. works great and the only time i would have a potential problem is in an electrical storm and a lightning strike (same problem frankly that a heater with a fan would have..power goes out, your screwed)..so..whatever you do, shut the heater off in an electrical storm
    Jul 2006
    Hey Jeffski, is yours an electronic ignition Mini max or Millivolt? Mine is a minivolt I am pretty sure it doesn't have a fan... since there is no power going to the unit to power one.
    Is there anyone who has a minivolt setup that can take a picture of their timer and setup?
    Have you tried contacting Pentair (1-800-831-7133)?
    I figure there has to be some kind of a device to connect between a typical timer/fireman switch and the thermostat board.
    *** Don't try the following at home ***
    It seems like a transformer to step the voltage down and then a low voltage relay should do the trick. But this is normally where someone jumps in with why didn't you just buy X instead of doing that? Actually you'd want to change the voltage to DC to reduce the chances of inducing a current in the low voltage line due to magnetic fields. I'd still be somewhat concerned that voltage spikes could be sent when the relay is tripped.
    Yep, mine is the Mini Max and has an electrical connection.
    Jul 2006
    I called pentair and they told me that the tech dept has repeatedly told them (sales and customer service) that all their heaters do not require a cool down period... now with that being said, they told me that the tech dept will call me back in the next couple of days to confirm this.
