No I would have to say you would have to have some pretty good knowledge on how the a/c system works.
I set mine up so it will switch between the air condensor and the water cooled condensor based on pool water temp.
Some of the basic parts need are a liquid ref reciver tank, water cooled condensor, solenoid valves, High and low pressure cut out switches.
I used my 12 year old 10 seer condensing unit, I also increased the eff.of the unit because on the Hot days rather than 90 to 100 d air temp going accross the air cooled condensor it is 80 to 85 pool water.
Can you post pics on this forum I would show you a pic?
