Thread: Learned My Lesson
    mbar's Avatar
    Ashland, PA
    Default Re: Learned My Lesson
    Yep, a good lesson learned!
    Northeast PA
    steveinaz is offline Lifetime Member Weir Watcher steveinaz 2 stars steveinaz 2 stars
    Southern Arizona
    I test for ph and FC/CC on Wednesday's and Saturdays. The SWCG does the chlorinating, and I make adjustments, if necessary, based on what I see. My ph is stable to a point where twice a week is all that is needed. Skimmer and pump baskets are checked daily.
    Jul 2006
    Middle of the mitten , Mi
    I forget who told me to take the cover off for a bit every day or longer if going for more days without the cover off .
    Something about gas lock , anyone join in and correct me . But it seems if the pool doesn't breath a bit from time to time , the gases lockup and it won't let your FC work like it should .
    Sooo even if it's cold out I try and get the cover off for a 2 hours or so every other day .
    Hope this helps ya and gl .
    ChuckD is offline Unconfirmed User Weir Watcher ChuckD 0
    Duanesburg, NY
    Quote Originally Posted by Sprocket View Post
    I've got plenty of evidence it's a myth, but I wouldn't swear to it.
    Our pool's at our place-in-the-country-soon-to-be-our-primary-residence. For two years now I've kept the solar blanket (cut to fit) on for the couple weeks between visits and suffered no algae blooms, nor any other contamination. At first I did have something which turned out to be my ignorance of the reaction of Cl, iron-rich water and sunlight. But all last year I never opened the cover and had to do much more than vacuum a bit and add some Cl. The cover would have been on for two to three weeks at a time. And the pump was timed to run two periods of four hours each day.
