Results 1 to 10 of 12
Thread: Is there any way to pressure test laterals
    Default Re: Is there any way to pressure test laterals
    I also get sand in the pool from who knows where. Let me know if you figure it out.
    ScottS is offline Registered+ Thread Analyst ScottS 0
    Covington, LA.
    Me too as I posted on the other thread. I'd like to hear other comments.
    I just noticed your signature line Nicole. You've got a 1.5hp pump. What size is your filter?
    Attleboro, MA.
    I put a ball valve on the return line that should cut down on the hp of the filter. Also the package was sold as a set and I'm told that this filter/pump combo is ok. And also the first year that I had the pool the pool was sparkling clean. I would only vacuum once a week. Then the following year the standpipe had some problems so I replaced that and have had problems every since. The filter is a 150lb Astral Millenium 17"
    Nicole: 18' round AG with AstralPool Sand Filter and 1.5hp AstralPool Pump
    you can only pressure test things that are sealed, since laterals consist of a bunch of small holes, you can't.
    You just switched your zeo over, likely what's happening is that crusehd zeo dust (happens during shipping/handling) is making it's way through the filter and back into the pool - 2 ways that should be able to eliminate that - vac it to waste, or, add DE to the filter, let run for 1/2 hour, vac on filter and backwash.
    Nicole - the dirtier you allow your filter to get, the better it performs - I have a felling you backwash a lot and never allow your filter to collect a nice fine layer of dirt on top of the medium which adds to the filtering capabilities....
    Attleboro, MA.
    We had about 2" of rain yesterday so the pool is very full so today I'm going to vac to waste to get the water level to where it needs to be. I have added DE.
    I agree that I backwash often and don't go by the pressure, I feel if it's been a couple of weeks and don't see the pressure rise that I must need to do it anymore. I'm not going to do that anymore. I'm going to wait until the pressure rises 6-8lbs.
    Honesdale PA
    Matt is right about testing. As for cracks in the laterals, any crack big enough to let sand thru, you will see and it will be obvious. You mentioned that 'tape on the standpipe' trick so you must have been reading the archives. I think I mentioned that a couple years ago. For those that haven't seen the post, it is my suspicion that Hayward (my filter) designed the fit between the center pipe from the laterals and the top mount valve pipe to be a very loose fit. This lets air trapped in the top of the filter to bleed back to thr returns quickly. I added a few layers of black vinyl electrical tape to the top of the pipe to reduce the clearance but not seal it. It now takes a little longer for the returns to stop bubbling when I get air in the filter....from the vacuum hose when I connect it...but so what? I never had a sand blowby issue so I don't know if it did any good. But it didn't hurt things either.
    Attleboro, MA.
    Again today I took apart my filter, very, very carefully inspected each lateral, the standpipe. Everything is in PERFECT condition. The filter for some reason is still letting in a very fine dust. When I vacuum it up I use the scum bags and it resembles pollen it's so fine. I'm hoping that maybe once my media gets dirty it will start to filter out the fine stuff.
    My numbers are perfect so I know it's not algae, just took them today:
    FC 14
    CC 0
    CYA 80
    ALK 80
    PH 7.6
    Also when I put a panty hose on the return it catches it all.
    I'm just at my wits end.
