Thread: Filter losing suction
    Dallas, TX
    Default Filter losing suction
    I have a sand dollar filter, going on the 5th year now. Replaced the head last year. This year I replaced the sand and started to get the pool ready for summer. The filter seemed fine... but everytime I vacuum after about 3-5 minutes I start to lose suction. It comes back after I flush the filter and then go back to vacuuming.
    Anyone know what could be causing this? I am afraid I might be stuck buying a new filter this year.
    Honesdale PA
    Default Re: Filter losing suction
    Welcome to the forum.
    Some questions.
    --What kind of pool, just curious.
    --When you lose suction does the pressure at the filter rise? This would indicate the filter is plugging.
    --When you lose suction are there air bubbles visible either in the pump basket or coming out the return(s)? Tiny crack or leak on the suction side somewhere.
    --Is there a lot of crud on the bottom that you're vacuuming? Plugging filter.
    --Finally, does the system run fine in the normal configuration i.e. using the skimmer and not vacuuming? If it only has a problem when vacuuming then I'd suspect a crack in the vacuum hose.
    Best I can come up with for now at this later hour.
