Results 1 to 10 of 14
Thread: Totally Frustrated!!!!!
    Indiana.
    Default Re: Totally Frustrated!!!!!
    Quote Originally Posted by kecsmom View Post
    the readings at the pool store today were: FC 3.9; TC 4.4;CC 0.4;ph 7.9
    You won't get anywhere letting your chlorine get that low or relying on the pool store for testing. The water will have to be tested several times a day, with chlorine added as required. You also need to push your pH down with muriatic acid.
    mbar's Avatar
    Ashland, PA
    John T is right, you need to get your chlorine level to 20ppms consistantly - lower your ph to 7.2 and bleach, bleach, bleach. By lowering the ph, your chlorine will be more effective. Do not test ph after you have brought the chorine up to 20, because high chlorine will make the ph test inaccurate. If you test 3x a day and bring your chlorine back to 20 ppms each time, I promise you will have a clean clear pool in a couple of days Consistancy is the main ingredient - follow the best guess chart:
    Use the info in this chart to help you figure out what levels of chlorine you need to maintain in your pool based on the amount of CYA (cyanuric acid, also called stabilizer) that you have in your pool. (FC = free chlorine)
    Stabilizer . . . . . . Min. FC . . . . Max FC . . . 'Shock' FC
    => 0 ppm . . . . . . . 1 ppm . . . . . 3 ppm . . . . 10 ppm
    => 10 - 20 ppm . . . . 2 ppm . . . . . 5 ppm . . . . 12 ppm
    => 30 - 50 ppm . . . . 3 ppm . . . . . 6 ppm . . . . 15 ppm
    => 60 - 90 ppm . . . . 5 ppm . . . . . 10 ppm . . .. 20 ppm
    => 100 - 200 ppm . . . 8 ppm . . . . . 15 ppm . . .. 25 ppm
    Don't listen to the pool store, you will be fighting the pool for a couple of more weeks. I know it is hard to believe, but using the bleach really does work. Let us know how you do, and if you have any other questions
    Northeast PA
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    There are several actions you can take to minimize pool maintenance.
    We have a 26000 gallon round above ground system and use the following:
    Salt Water Chlorination system - Had our system for two years and the pool is always sparkling clear. I do add Muriactic acid about twice a month to keep PH in check. At the beginning of the year I had to add some additional salt and stabilizer this year as we had so much rain during the spring it overflowed the pool and though off the chemical balance.
    Pool Skimmer - Looks like a little miniature toilet bowl. Works off your pool return line. It skims the top of the water before it goes into the skimmer basket. Makes a major reduction in the junk your pump and filter have to deal with.
    We purchased one of the the larger (SD 80) sand filter systems but instead of sand are using Zeolite. We've had to backwash the Zeolite 4 time in two years and the pool still looks sparkling clean.
    We use a combination of a Pool Rover and Pool Buster to pick up the debris that the skimmer misses. The Pool Rover takes about 2 hours to complete the job but works great.
    Pool maintenance is not hard if you try to automate where you can and spend about 5-10 minutes per day making sure nothing has changed. When I get home I usually start up the Pool Rover, check the display on the Aquarite for any messages and do a quick chemical test.
    Chemical adjustments and changes require patience but are simple to learn. If I add or change anything I wait at least 2 days for measuring results. If the water is cloudy it's because you have sediment floating around in it. Start with the filter system and make sure it is doing what it's supposed to. If that's not working right then chemical balancing and treatments will have a hard time trying to clean up your water.
    33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
    Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
    Aqualuminator with Fountain -- Solar Pool Lights
    Pool Pictures at the link below
    http://community.webshots.com/album/548241672nKeuyR
    Jul 2006
    Middle of the mitten , Mi
    Post Re: Totally Frustrated!!!!!
    Good stuff all said .
    I might add this
    cya 70 <-- bingo do a search on my name Sprocket and see my problems and how I solved them using this bb's board good advice .
    Untill I got my CYA down it was very hard to keep the green away , now mine is 30 it's a breeze again . High CYA = having to have high FC readings in your pool to do the same cleaning action that lower FC does .
    From what I have learned to high CYA just defeats the cleaning action of chlorine . While having no CYA lets your pool chlorine disapper in sunlight in just a few hours time .
    The way I did my fix was to get the water lvl down and add new water without CYA in it ( well water ) and to use bleach to shock till CC went to 0 and for everyday use I keep FC to 3 - 6 .
    I was using pucks and powder shock and both of those have CYA in them , causeing my CYA readings to go to high and then the green appeared .
    Plus untill you fork over the coin to get you a really good test kit , your gonna be at the pool stores mercy IMO . That's a MUST as JohnT pointed out .
    I am using about a quart a day of Ultra beach atm and it's so nice to jump in and not see GREEN on my sand dimples anymore .
    Read , learn and follow advice , way cheaper to do it the right way then to "think" your saving money any other way IMO .
    I "shocked" my pool just once this year when I opened it up ( 5-27-07 )after being covered for 9 months , using 6 3/4 gals of Ultra Beach from Save a Lot store at 1.18 USD a jug
    I did spend 67 bucks on a Good Test Kit though .
    I learned , and now I go to pool store and laugh when I leave cause they didn't sell me but what I wanted to buy Last trip they told me that the more CYA in my water the better , how nice of her to tell me wrong info just to sell more of their product .
    enough said .
    gwrace1 , I want a Pool Rover next time I buy for my pool , I been reading nothing but good reports like yours on using them in AG pools
    I read about that skimmer also , good item , but I have a light on my return and don't think that will attach , at least from the pics I have seen of it online .
    heymom1 is offline ** No working email address ** heymom1 0
    I have a mild case of mustard algae right now. I think I understand some of the chemistry behind the BBB method - the pucks have stabilizer which can get too high, but you need some stabilizer or you can't keep your chlorine level high enough to kill the bugs.
    If you use household bleach instead of pucks, since it contains no stabilizer, how do you keep your chlorine levels steady? Do you add a gallon or two every single night? What happens if you leave town?
    I don't have a reading on my pool levels yet - son is out doing a test now - but we've added some shock to start killing the algae.
    Well, son just came in and said the CYA is 100. 29K pool. Is that high?
    mbar's Avatar
    Ashland, PA
    Yes, cya of 100 is high. It doesn't matter how many gallons the pool is. The level of cya acts the same in all pools. It is ok to have a cya of 100, but then you need to keep a minimum of 8ppms of chlorine, and your shock level would be 25ppms.
    Northeast PA
    Question Re: Totally Frustrated!!!!!
    Thank you for your answer. The algae is not visible this morning, so I guess the shock level is high enough. I will test all the levels myself today, and post the results. And keep adding bleach if I need more chl.
    How do you deal with vacations if you are using just bleach added every night?
