Re: Totally Frustrated!!!!!
There are several actions you can take to minimize pool maintenance.
We have a 26000 gallon round above ground system and use the following:
Salt Water Chlorination system - Had our system for two years and the pool is always sparkling clear. I do add Muriactic acid about twice a month to keep PH in check. At the beginning of the year I had to add some additional salt and stabilizer this year as we had so much rain during the spring it overflowed the pool and though off the chemical balance.
Pool Skimmer - Looks like a little miniature toilet bowl. Works off your pool return line. It skims the top of the water before it goes into the skimmer basket. Makes a major reduction in the junk your pump and filter have to deal with.
We purchased one of the the larger (SD 80) sand filter systems but instead of sand are using Zeolite. We've had to backwash the Zeolite 4 time in two years and the pool still looks sparkling clean.
We use a combination of a Pool Rover and Pool Buster to pick up the debris that the skimmer misses. The Pool Rover takes about 2 hours to complete the job but works great.
Pool maintenance is not hard if you try to automate where you can and spend about 5-10 minutes per day making sure nothing has changed. When I get home I usually start up the Pool Rover, check the display on the Aquarite for any messages and do a quick chemical test.
Chemical adjustments and changes require patience but are simple to learn. If I add or change anything I wait at least 2 days for measuring results. If the water is cloudy it's because you have sediment floating around in it. Start with the filter system and make sure it is doing what it's supposed to. If that's not working right then chemical balancing and treatments will have a hard time trying to clean up your water.
33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
Aqualuminator with Fountain -- Solar Pool Lights
Pool Pictures at the link below
http://community.webshots.com/album/548241672nKeuyR
