Yes, cya of 100 is high. It doesn't matter how many gallons the pool is. The level of cya acts the same in all pools. It is ok to have a cya of 100, but then you need to keep a minimum of 8ppms of chlorine, and your shock level would be 25ppms.
Northeast PA
Thank you for your answer. The algae is not visible this morning, so I guess the shock level is high enough. I will test all the levels myself today, and post the results. And keep adding bleach if I need more chl.
How do you deal with vacations if you are using just bleach added every night?
If you have a neighbor or nearby teenager that you can trust to pour a gallon in every couple of days or so, that's really the best way to deal with vacations. My down the street neighbor comes to my house daily to deal with my animals, anyway, so it's not a problem for her.
In the absence of someone reliable to stop by to put bleach in, you could shock it really well before you leave (if you're only going to be gone for a week and have a CYA of 100, then it would probably take a week for your chlorine levels to come back down. Or you can buy a floater and put cal-hypo pucks in it for a slow constant chlorine feed.
Janet, thanks for the response. We don't have any nearby teenagers, and we're taking our with us, so the option to pour bleach in is out. We'll be gone 10 days total. My FIL can come by and check on the pool, but he can't come every night. We have the inline feeder anyway, so I can just keep that going until we get back from our trip. Why can't they make the pucks with less stabilizer anyway? Well, maybe it just builds up no matter what...
I can leave the chlorine very high - the CYA level today is more like 90, so I don't think we will have a lack of chlorine. The chl level today was way over 5, but the kids went in for a while just now. My kit doesn't test free and combined, just total. I need to get one of Ben's kits - is he selling them now?
Thanks again for the help. This forum is invaluable.
Unfortunately, Ben doesn't seem to be in the kit business just now--it's been awhile since he's paid any attention to the forum and in fact has a very long list of people who have already bought kits and are waiting for them to be delivered. My suggestion is the Taylor K-2006, which is almost the same kit, and can be found at most pool stores or online.
In answer to your other question about vacation, if your FIL can come by and check on the pool say every 2-3 days, can he pour in a gallon of bleach? If you shock it before you leave with a CYA of 90 and he comes over, say, twice to add more bleach, then you should be fine. An alternative would be to get a new floater and cal-hypo tabs. THey don't add stabilizer. The newest ones really are not great because they dissolve too quickly and get kind of mushy, but they might do in a pinch.
I think personally I'd just shock it to the upper end of the recommended chlorine range, ask FIL to come by in about 4-5 days and pour in 2 gallons of bleach, and then take my chances. Beats worrying about it the whole time you're gone!
I have a Taylor test kit , works good and easy to use . You
can buy refills from Taylor themselfs online , it's seems to
be the cheapest spot .
I bought my kit online , just did a yahoo search and then hunted for the
best price "with" shipping .
When you get your CYA down , it will stay steady also till you drain and refill your pool . Or you drain alot because of rain .
When mine droped I just added Cond. to the pool again , 1.5 quarts and then wait a week to retest . It's fine again , taking about a 1 quart of Ultra bleach a day .
how do you keep your chlorine levels steady?
I check once every other day and add a jug (3 quarts ) of Ultra
bleach when the FC drops below 4 . But my CYA is only 30 , and yours
is 90 -100 I guess . Your gonna have to have your FC much higher readings
to kill the "bugs" as u stated .
Or you can check each day and add a quart at a time .
Every time you use a tab or a powder shock product your adding more CYA to your pool and making it so you have to have more FC to kill the "bugs" .
I have 40 plus lbs of tabs and 4 bags of "shock" left that I don't use unless my CYA drops below 30 .
Did you do that search ? I used that alot , search for answers from other peoples problems . We mostly have the same ones over and over .
Yes VacI am dreading it . Last year my "friend" helped me by adding cond. to my pool as he said "it helped my clorine to work better"
I am hopeing on someone to come every other day and check FC and all bleach . So far my wife hasn't found that certain someone .
Get that test kit asap . Lower your cya lvls . Don't use anything with CYA in it till you want to raise that reading . Your gonna be alot happer . Just cause you can't see green "yet" doesn't mean it's killed . Trust me .
Thanks, Sprocket - that answers a lot of questions. I won't hold my breath waiting for one of Ben's kits then.
I can't do the BBB method until all the trips are over - there is no way anyone will do that for me and even hubby is skeptical of the bleach-only method. So the CYA will just stay up there until I can get back and do a drain, or if we keep getting rain. The pucks are feeding and the pump is running 24/7. I'm a bad forum member right now!
Next year we are planning to go to Europe. Sigh....
