Thread: Crack In Skimmer
    Jul 2006
    Altamont,NY
    Default Crack In Skimmer
    I have a hair line crack at the back of my skimmer, It is about 2" long and is just below the skimmer basket. Is there anyway to fix this this without draining the pool?
    duraleigh Guest
    Default Re: Crack In Skimmer
    Without draining below the crack to make a dry fix, I would say you'll have limited success. You just can't get a good underwater bond.
    Drained below the crack, two-part epoxy glue would be my first choice. Still has to be done carefully to get a lasting repair.
    Honesdale PA
    I did a major patch on mine a few years ago. Accidentally punched a major crack through the bottom just inside the opening. Had to drain a little so the area was dry. Used a mixture of ground up PVC pipe and PVC solvent. Applied the thick paste over the crack. Been holding fine since. Ground a piece of pipe with a rasp file. Can also use a coarse saw or anything to make small chips. Success depends on whether PVC solvent attacks the skimmer material. Try a little solvent with a Q-tip on a surface to see if it attacks the material. If it does, go for it.
    While I'm sure that doing it dry, as per Dave and Al, will help to insure that the leak seals, I've had very good success using underwater 2- part epoxy. I think Al's method will do a better job than either Dave's or mine, but as he says - it will depend on whether the solvent will sufficiently soften the skimmer plastic.
    Good luck with the repair, if you have any ?s about the 2- part epoxy, just holler
    edit- see https://poolforum.com/pf2/showthread.php?p=48692
