Thread: Hard to Open Hayward Northstar Strainer Cover
    mas985's Avatar
    Pleasanton, CA
    Default Re: Hard to Open Hayward Northstar Strainer Cover
    If lubing it doesn't work, I sometime losen mine while the pump is running. The suction helps a bit to get it started.
    Mark
    Davenj is offline Lifetime Member Thread Analyst Davenj 0
    Jersey Shore
    My Northstar was hard to open the first season, always had lube on the o-ring. This year its a little to easy, going to replace the gasket. With the lube check for grit or junk stuck to the o-ring and mating surface.
    joelq is offline Registered+ Thread Analyst joelq 0
    Frisco, TX
    Quote Originally Posted by mas985 View Post
    Hi Mark - I tried your technique this past weekend and IT WORKED! It was so much easier to turn that cover with the pump running. Thanks for the suggestion!
