Thread: Advice please.
Threaded View
  1. #4
    Default Re: Advice please.
    OK. As I said above, since your cya is a little high you either have to run higher than normal chlorine readings (see link above) or do a partial drain to lower it a bit. Your choice. Either way will work. Also, you need to lower your alk to between 80-125. You can read about how to do this in the thread at the following link.
    http://www.poolforum.com/pf2/showthread.php?t=191
    BTW: Until you lower your alk to the desired target, disregard my advice in the earlier post to raise ph. After your alk is where you want it, if the ph doesn't rise up on its own, then you can add a little Borax to raise it to about 7.4.
    Watermom
  1. need advice on what do to first
    By sherraechas in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-26-2012, 02:44 PM
  2. Hot tub advice
    By myatinsel in forum General Interest
    Last Post: 10-19-2011, 03:02 PM
  3. Hello All need some advice.
    By 55fordtruck in forum Dealing with Algae & Slime
    Last Post: 08-19-2011, 10:28 PM
  4. Need some advice
    By sherron100 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-10-2011, 08:33 PM
  5. 18' AG Advice
    By cramar in forum Above-Ground Pool Construction & Repair
    Last Post: 11-19-2010, 03:05 PM
