Re: Pucks
There is a cal hypo product in a different form that does not have cya but its not used the same way as the trichlor pucks and you CANNOT mix trichlor with cal hypo - yikes.
If I am going on vacation for a longer time without someone to babysit the pool, I will clean well, superchlorinate/shock, cover and set my pump timer to run longer than usual. I have never had issues.
