Results 1 to 10 of 57
Thread: Fighting Algae with Borax
    topless is offline Registered+ Thread Analyst topless 0
    Jul 2006
    Wichita, KS
    Default Re: Fighting Algae with Borax
    I paid $2.67 per box at Walmart.
    Prior to adding the borax, I was having to add 5-6 lbs of cal-hypo or more per day and keeping the fc above 20 ppm. 2 days now, I added 1 bottle of bleach to keep fc above 6 ppm, my cya is still close to 50.
    I'm having trouble letting go of continuously adding chlorine, it's become a habit.
    topless,
    I'm glad the Borax is working for you and it's good to know that it seems to inhibit yellow/mustard algae. Prior to your experience, we only saw that it seemed to inhibit the much more common green algae.
    By the way, to shock yellow/mustard algae we figured out (through a few users experiences on this forum) that it takes lowering the pH to 7.2 and then raising the FC to 60% of the CYA level (instead the usual 40% for green algae) and holding it there for at least 2-3 days. In your case that would have been 30 ppm FC. Then to keep away the yellow/mustard algae if it gets reintroduced it would take a minimum FC level of 15% of the CYA level or 7.5 ppm FC in your case. In this post you said you had to shock at 25 ppm FC or else the yellow/mustard algae would return in a few days. So that's close to the 30 required for shocking this algae, but was the subsequent maintenance level required to keep it away 7.5 ppm or something else -- the post sounded like dropping anywhere below 25 ppm FC would have the algae return? I just want to confirm that you weren't seeing anything inconsistent with "first 7.2 pH then 30 ppm FC shock then 7.5 ppm FC maintain" at 50 ppm CYA, since this is the advice we are currently giving (and now we can say that Borates will help as well).
    Richard
    Jul 2006
    Wichita, KS
    I was trying to keep the ph at 7.2 and aerating it to lower my TA. When it would get back to 7.4, I added a quart of acid to lower it back down.
    I had a tough time keeping the FC above 25 and I was trying to keep it over 30, but the algae was consuming 15-20 ppm every 12 hours especially during the day. That's part of the reason I went to cal-hypo granules and 3" pucks, I was buying 30 bottles of bleach at a time and went through 60 bottles in one weekend. The cal-hypo allowed me to keep the FC higher with less trash. Along with adding 5-6 lbs of granules ( in my pool that should equal 4ppm per lb)I would put 2-3 pucks in the skimmer and 4-6 in front of discharge nozzles, in an attempt to keep the FC up. At one point I added 12 lbs of granules and raised the pool level trying to kill anything and everything. After that, it was easier to keep the FC near 30.
    With this amount of FC, the pool was clearing, but the last 2-3 days it seemed to be stalled out leaving the deep end cloudy at the bottom.
    It rained again yesterday, so the cover has been closed. If the sun stays out today (40% chance of rain), I'll open it this afternoon and test again. Hopefully, the pool will still be clear.
    When you have that much junk in the pool, it sometimes helps to vacuum to waste if it is settled at all (perhaps when the pump is off for a short time). Chlorine will break down algae, but when there's a whole lot of it then it is sometimes more efficient to remove the bulk directly or via the filter and frequent backwashing (for sand filter). In some cases, a floc helps consolidate the particles and settle to the bottom to make vacuum to waste easier and usually that is a last resort, but it really depends on how much there is to clear. Though chlorine can clear it, there's a tradeoff between how much chlorine you're willing to use vs. doing physical removal. When most people use chlorine, they are also doing some sort of physical removal as well whether that's vacuum to waste or regular cleaning out of the filter.
    If your pool doesn't have a floor drain, then circulation can be poor at the bottom so vacuum to waste (possibly after a floc) may work better in that case.
    Anyway, it sounds like the shock level worked except for the large bulk of material and possibly poor bottom circulation, but avoidance is easier and hopefully the Borates will work long-term for you.
    Richard
    Jul 2006
    Wichita, KS
    UPDATE:
    Opened the pool for the first time since Sunday evening. Crystal clear water (I was concerned) I ran tests: (I haven't received my borate test strips yet.)
    FC -1.5
    cc- less than .5
    ph- 7.3
    temp -81
    cya - under 50
    TA - 160
    More rain is forecast, so I added a bottle of bleach and closed it back up.
    I'm no chemist, but I'm a believer in borates.
    I'm not trying to hijack this thread but I'll ask for advice for a friend who can't post here. Assuming no borates are present, how much borax and how much acid would be appropriate for an Intex pool w/7200 gallon capacity? Do you think it's safe for her to use liquid acid in an Intex pool? Thanks,
    Hal
    each 60 oz borax raises 1000 gallons 50 ppm and requieres 30 oz of acid. Each box of 20 mule team is 76 oz. I am going to assume 7000 gal of water which sould be fine so your friend would need 26 1/4 lbs borax (about 5 1/2 boxes) and 1 1/2 gallon and about 1 pint of acid. The acid should be fine in an intext pool. Put in half the borax (presdissolved), then 3/4 gallon of acid (3 quarts)--you might want to add it a quart at a time by putting each quart into a 5 gal bucket of water first and then broadcasting it into the pool, always add the acid to water--NOT the other way around), brush the pool well to mix it up. Then add the rest of the borax and the other 3 quarts of acid and brush and let it circulate for about 24 hours. Test the pH and bring it back down to 7.6 with the rest of the acid. You might need an ounce or so more to get to 7.6 over the pint.
