Thread: Added CYA and pH took a dive...
    Default Re: Added CYA and pH took a dive...
    Cyanuric acid often will cause a pH drop when you add it. As long as your pH doesn't drop below 7.0 I would not worry too much about it. Where is your TA? A full set of test results would be helpful.
    Edit: by full set of test results I mean Free Chlorine, Total Chlorine, pH, Total Alkalinity, Calcium Hardness, and CYA done with a drop kit or dry reagents and not strips.
    Front Royal, VA
    Can do, a couple of questions about that...
    I use a Taylor K-2005 and when I do the TA test, I have a green sample and it tells me to add drops until it changes to red. Does the reading happen when it stops being green or when it becomes a true red? I think it's purple before it's red.
    For CYA, the kit suggests to add the water + reagent combo until a black dot starts to disappear. Does that mean when it turns grey or cloudy or when it's gone?
    Maybe I need to ask Taylor...
    FC = 2.5
    TC = 3
    pH = 7.2
    TA = 160
    CH = 140
    CYA = below 30
    PS...Just reading one of Carl's posts tells me my CYA must be around 20 because the TA was 140 yesterday and it's 160 this morning...
