Thread: Ph problems
    Beaver Falls, Pennsylvania, USA.
    Question Ph problems
    I just opened our above ground 18 round pool. I tested the ph and it's a very light slightly orange color. I use the 6 test tester that you'd buy at places like Walmart and it doesn't even show colors that light. What would I add? Baking soda or borax to bring it up? Any ideas how much?
    Thank you!
    kristin
    Default Re: Ph problems
    Use borax to bring it up to range.
  1. Problems!!
    By lorettasweet in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-02-2007, 09:44 PM
  2. CYA Problems
    By maureenq in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-05-2007, 07:47 AM
  3. Pump Problems!
    By scooter hotrod in forum Above-Ground Pool Construction & Repair
    Last Post: 08-23-2006, 01:09 PM
  4. Chlorine Problems
    By acmtn in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-01-2006, 05:32 PM
  5. More Problems
    By p.p.h. in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-30-2006, 10:33 PM
