Re: LaMotte ColorQ Water Tester
Great! It is nice to know there is more than one source.
Unfortunately, I am not able to use my ColorQ (see above). If you have high CH, think twice about using this system. Mine is in the 500-600 range, which people on this forum consider to be more than manageable. This is only a bit over the range of the CH test in the ColorQ, but it is "buffering" my results per LaMotte. I am pursuing a refund right now.
Salinda
