Results 1 to 10 of 10
Thread: Question on how to match color on drop test kit
    Jul 2006
    Default Re: Question on how to match color on drop test kit
    So, it appears my kit does the DPD test, rather than the FAS-DPD?
    Ed
    DPD tests will bleach out at shock levels and appear to read very low when the chlorine levels are high. This is one of their biggest drawbacks and one of the reasons I personally prefer the FAS-DPD titration test for chlorine.
    Thanks,
    Ed
    33,000 Gallon
    20'x40'
    Vinyl
    IG
    Yes, DPD is a color matching test where you match different shades of red to a color comparator, FAS-DPD is a titiration test where you add drops until the sample turns from red to colorless.
    + on the idea of looking against a white background instead of the sky, etc. i accidentally did that this morning when i had the test kit sitting on a white melamine shelf and thought wow..i can really see the differences in colors now
    Columbia, SC
    Talking Re: Question on how to match color on drop test kit
    Well, in Ben's kit he has some instructions that read:
    " Note: for OTO & ph testing, use white inside label as background."
    18,000 IG Gunite/Plaster, Hayward Sand Filter
    i'm a po' poolboy..test kit from local hardware store what instructions?
