Results 1 to 10 of 12
Thread: Cleaning a DE Filter
    Steve #1 is offline ** No working email address ** Steve #1 0
    Default Cleaning a DE Filter
    I know there was a discussion recently on the best way to clean a DE filter, but I can't find the thread. Could someone point me to it or remind me what the consensus was?
    Also, I'm guessing that big clumps of DE and dirt packed between the grids is a bad thing. Should I be concerned, or just assume that the previous owner hadn't cleaned it in a while?
    Amir is offline Registered+ Thread Analyst Amir 0
    Potomac, MD, USA.
    Default Re: Cleaning a DE Filter
    If it is not too bad, take out the whole thing and hose it down. If the grids do not clean this way you need to disassemble the grids and wash them separately from inside and outside.
    I found the thread I was looking for. Waste had linked to it in a post he made yesterday.
    http://www.poolforum.com/pf2/showthread.php?t=6811
    Cool Re: Cleaning a DE Filter
    Steve, there are a couple other posts to look at (I finally made myself a list of them )
    Take a few minutes and check here and this and this bad boy
    Thanks, I read those when I found the other post.
    I couldn't remember what you had said to wash it in (the dishwasher detergent).
    I got it rinsed good now I'm off to the store for the detergent and some fluids to replace the ones the mosquitoes just removed from my body. I'm thinking if I get my BAL high enough, after a few bites the little guys will be to drunk to fly.
    Lenny is offline Lifetime Member Thread Analyst Lenny 0
    Wilmington, Delaware
    When I backwash, I reverse the flow a few times for a few seconds after the sight glass is showing clear water. I realize you aren't supposed to run the filter when no DE is in there but I don't do it long. This always kicks up more DE and the sight glass shows cloudy water again. I think this may have been why my grids were so clean when I opened the filter this year. They were clean enough to where I didn't bother pulling them out this time to clean them. They were very clean.
    Does anyone else do this?
    Smile Re: Cleaning a DE Filter
    Lenny, if I really want to do a good backwashing - I'll do backwash/rinse 3- 6 times then add a ~1 min filter cycle and backwash/rinse again. Getting the water running the oposite way seems to loosen up more of the DE so you can get a little more of it out. (to prevent any 'back-talk' -- I rarely backwash filters, it's just easier to break them down and hose them off, and this way I can see if the homeowner has been under or overcharging the filter )
