Thread: cal hypo shock
    ohio
    Default cal hypo shock
    A friend gave me some 1 lb bags of cal hypo shock. I have 12,000 AG pool and normally just use more bleach when I shock.
    Can I use this for shock or should I just stick to bleach?
    my numbers:
    Fc 5
    cc .5
    ph 7.2
    alk 100
    cya 30
    ---Dale
    ohio
    Default Re: cal hypo shock
    I haven't tested calcium this year since I have a vinyl pool. But I'll do it and post my results tomorrow.
    I'm guessing if my calcium is not too high, it's ok to use the cal hypo? And if it's high, stick to bleach?
    thanks.
    ---Dale
    ohio
    my calcium is 90. Can I use the cal hypo shock?
    Quote Originally Posted by dalejanus View Post
    Sure! If your Cal was in the high 300's or the mid 400's I'd say no, but 90? Use it and save money!
    BTW, they may call it "shock" but it's not. It's simply Cal-Hypo packed in pre-measured bags.
    "Shock" is a verb, something you do to your pool. It's not a noun, it's not something you put in it.
    But the pool chem industry likes to bend the language to make it sound like you are buying more (and paying more) than you actually are.
  1. cal-hypo shock white cloud finally gone!
    By Cords in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-08-2011, 10:44 PM
  2. Newbie: To shock or not to shock... That is the question
    By KaseyNewman in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2011, 04:50 PM
  3. difference between cal hypo and sodium hypo (from bleach)
    By kasatpoolforum in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-20-2010, 08:12 PM
  4. Cal hypo shock conversions....
    By chrisexv6 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-27-2006, 04:20 PM
  5. 65% Cal Hypo
    By Sherra in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-12-2006, 02:02 PM
